Model Object component update problem
I’m slightly overworked and about to freak out due to Grasshopper Rhino component not updating.
Steps to reproduce the problem:
  1. Open the Grasshopper file and click ‘update’ to bake some geometry.
The two panels should show the same full layer names.
  1. Change a layer name of a child layer and maybe a color.
The python script has the correct output and the Model Object component doesn’t update
The Model Object component only seems to update when the geometry within a layer changes. It only updates the list item where geometry has changed.
I’m not sure if this is how it is supposed to happen?
A python script outputs the correct layer name, even updates somewhat in real-time.
The Grasshopper file includes data which can be baked into layers for testing.
layer_problem.gh (45.6 KB)
System Info
Rhino 8 SR1 2023-11-7 (Rhino 8, 8.1.23311.13281, Git hash:master @ 0f88bb345f3e6574a4453f1846edc6d9c718fbce)
License type: Kommerziell, build 2023-11-07
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
.NET 7.0.13
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 10-18-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.70
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 10-18-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-18-2023
Driver Version: 31.0.15.3770
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23311.13281
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23311.13281
Hi @martinsiegrist,
This is fixed on 8.1 now.
Now all the content that came from a Query component expires when any change occurs on any of the ‘Objects’ or on any of the content is referenced from these objects.
If you disable Synchronise then the Query component will output a frozen copy of the objects that never expire until the component itself expires or the Query button is pressed.
Here I changed the ‘Layer 03’ color to magenta from the UI.
The synchronised content reflects the changes while the frozen one does not.
Thanks Kike, looking forward to try this myself.
