Model Block Definition - missing plane input
I’m missing a plane input to create blocks with the model block definition component.
It appears blocks can only be created with the XY plane as a base plane, which is a slightly different workflow from what I’m used to with EleFront from the past few years.
If a block should have a base plane which is not XY World, the geometry needs to be oriented from its arbitrary position to the XY origin to create the block and then the block instance component can be used to orient it back to its original position.
I think the model block definition component would benefit from having a plane input.
block_plane.gh (18.2 KB)
Actually it’s fine how it is. The transformation is applied to the block instance.
