I suppose this may be a general RDK rendering comment, but the Bongo dialog that lists the progress, as well as the progress box for rendering itself, should not be special high-priority windows popping up over everything else on my desktop unless something has caught fire. With this GPU rendering stuff I can actually render out an animation while working completely normally on other things, in which case these dialogs are a nuisance, especially the render progress one that you can’t change where it pops up. The only thing I MIGHT actually want to be able to grab and have sitting somewhere that I can see it regardless of what I’m doing MIGHT be the render output itself. Sometimes, maybe.
Do you mean it stays on top even when another application is active? I just realised this issues is: https://mcneel.myjetbrains.com/youtrack/issue/RH-35955 - 6 SR 3 will contain the fix for this.
