I use this script probably more than anything else.
It seems to get confused when you have a block instance inside a group as part of your selection… Would it be a heavy lift to correct this? My blocks are linked. I didn’t test with embedded. Not sure if it makes a difference.
Hello - I would, assuming you have V6, try the built-in V6 command and see what that does first… then shout if it has the same problem. A simple test file would be useful either way.
I’m still on V5. Upgrade soon. It’s really expensive having to do all the plugins at the same time… I didn’t realize V6 has a built-in. So disregard this. Not worth doing if I won’t need the script anymore. Thanks Pascal.
You do realize that if you upgrade to V6 you can still retain and use your V5? I see in the forum that many with plugins have taken this approach, allowing them to effectively use whichever version (5, 6, 7) is appropriate to their workflow. Makes the use of V6 and V7 improvements possible while upgrading plugins at your convenience.
