Will the broken printing of picture-frames and viewports in vector mode be fixed?
During V5 wip/beta we could print in vector mode, yet keeping picture-frames and viewports visible ( as embedded bitmaps) for a while now this is broken and iirc reported already.
I don’t believe this is broken. Only picture frames that are true rectangles can be printed with vector mode. If you’ve modified your picture frame by trimming or rotating, only raster will properly get the image printed.
If you mean the page/layout is in a technical mode, then no, the layout is just a plain page/layout
(I suppose in wireframe or whatever the default; is)
I place a picture frame in layout-space, and a detail in my custom technical_silhouette mode
A detail in regular technical mode, does print in vector mode.
See here: VectorPrintTest.3dm (310.6 KB)
Thanks for checking. So if you place a picture frame on a layout/page it does print in vector mode?
Did you also check the file I send (with my custom mode displaymode?) Not that you need to, but I’m curious upto what point it is working at your end.
your picture frame has a transparency map that is causing the problem.
Unchecking transp. map doesn’t help, you need to delete this and reinsert your picture frame.
Hoi Willem,
No, it doesn’t work in your file. Also, when I use the bitmap that I tried in your file, that one does NOT print either. So there is something going on in your file. No time to fiddle with this at this point, I’m afraid… Indien niemand anders iets vindt kan ik er morgen nog wel eens naar kijken.
cheers,
wim
I’m seeing what the other people here are seeing. Something is going wrong with that image. If I place a different picture frame in the layout, that picture frame prints just fine. I created a bug track entry (RH-22329) as a reminder for me to dig deeper into the problem when I get a chance.
The problem with the display mode also still persists, did you get a chance to test and see if that does that print in vector mode at your end?
Can you think of something I might need to reset, edit, check? As apparently my system is not functioning as expected I’d like to fix it yet I have no clue where to look for a solution.
Well, THAT picture is special cased in Rhino to never print Joking aside, that image does work on my Rhino.
Are your wireframe settings something other than default? You should be able to tell in the options dialog if the display mode is colored instead of just black.
No I’ve reset it to default. I will try and delete it to let it regenerate, just in case.
What strikes me as very odd, is that details in my custom mode do not print either, yet other modes do print just fine. Maybe I’m missing the obvious…
Thanks
-Willem
@stevebaer Hi Steve, sorry for bumping this but I’m about to start a project where it would be nice to have this fixed, and it seems I’m not the only one.
I’ve also noticed that something’s changed. I used to be able to picture frame images right on to my layout page and print out in Vector and at some point in the last few months, this stopped. I’ve reported it but didn’t get much of a response.
I have found a workaround, which is to place the pictureframed image in to modelspace and open a detail on my layout page that looks right at it. I then set the display mode in that detail to rendered, and I can print the overall layout page in vector mode – successfully, but I know that up until a few months ago, I used to be able to place the pictureframed image right on the layout page.
Wonder what changed.
Thank you, Willem for speaking up. I spend all day producing construction documents and this is an important element: )
