Hi people,
this looks like a very interesting project, what do you think?
http://www.mitsuba-renderer.org/
HI people…here,to solve an issue under mitsuba 1.0 beta!
when i try to export from rhino 5 a scene,the stand alone plugin starts correctly,but after 3 secs. appears a popup error
why?what can i do to solve it?i experienced this issue only under beta 1.0,also in mitsuba 0.5(but rarely)
It looks to me that you have a number format with decimal comma (0,05 means 0.05). If you change this setting in Control Panel => Region and Language => Additional Settings => Decimal Symbol and set this to ‘.’ (period) it may work better.
Ultimately, the Mitsuba render people should import/export their XML correctly, either respecting culture settings or ignoring them completely.
opsss…works fine!thanks a lot for your help!
do you have a solution also for this?i’ve experienced several kind of problems!
No, I don’t know. Speculation suggests that some shading or lighting parameter (beckmann,phong,…) has not been set (null value was found), but I’m really out of my depth here
You may have better luck in the Mitsuba support forum, if such a forum exists…
there’s a blog for support!
