The displacement inside the edges of the face causes problems later to execute the PushPull command, it does not generate the hole to the solid.
Link of the video where the problem is seen: Mistake Inner offset face edges + PushPull command.avi - Google Drive
hi @Valentina_Alvarez_Ro I tried to replicate something similar, but here it works as expected. In case you run into an issue like this, a video is most often not enough. If possible, always attach or send the model that shows the issue, thanks
