Missing template named
Hi, I’m having an issue with Rhino 8 on Windows 11. In the File → New template window, the template thumbnails appear normally, but the template names are invisible because the text seems to be white on a white background.
The template files are present and open normally, and I already tried repairing Rhino, but it didn’t fix the issue.
Could this be a font, UI/theme, or text-color issue? How can I reset the settings so the template names are visible again? Please help
I’ve attached a screenshot.
Hi Melina -
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Stand-Alone
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.21
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-12-2022 (M-D-Y).
    - Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.07
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-20-2024
Driver Version: 32.0.15.6607
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
Hi Melina -
Those drivers are very old. Open the Notifications panel in Rhino and follow the links (using the Details button) to the Nvidia site where you can download up-to-date drivers for your GPU.
.NET 8.0.21
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 9-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 616.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-4-2026
Driver Version: 32.0.16.1692
I updated the NVIDIA driver to 616.92 and restarted the computer, but the template names are still invisible
How can i fix this issue?
Your Intel UHD driver is also really old. Perhaps you should see if there is a newer one.
Is everything else working normally?
Yes I think
İs there any solution?
This is a one off report so we will need to troubleshoot. Updating the UHD is a good idea.
Are you using multiple monitors or just one?
Lets try repairing your Rhino first. Go to Control Panel>Programs>Programs and Features> Rhino, then right click Change and Repair.
I’m using only the laptop’s built-in display, with no external monitors.
I have already repaired Rhino, but the issue is still there.
I have now updated both graphics drivers. The Intel UHD Graphics driver is dated 6-17-2026, and the NVIDIA RTX 3050 Ti driver is version 616.92, dated 9-4-2026.
The template names are still invisible
Lets try this real quick.
Run SetDotNetRuntime and set to NETFramework
Restart Rhino. If this doesn’t do anything set it back to .netcore and restart Rhino
Itried NETFramework and restarted Rhino, but unfortunately the template names are still invisible. I have now switched it back to NETCore.
Thanks.
If you open Rhino then go to the Help pulldown and go to About Rhino do the templates show up there as expected?
Is Windows Smart App Control on? if so turn it off and restart Rhino.
The template names are also not visible in Help > About Rhino.
I checked Windows Smart App Control, and it is already turned off
I just installed Rhino and I’m planning to use it for my projects. I’m a little worried that this issue might indicate a bigger problem and that I could run into problems later while working on my projects. Do you think this issue could cause problems with Rhino’s functionality or affect my projects in the future?
This is a an odd one, but is seems to not be affecting Rhino in any other way.
Do you use various templates or set it and forget it?
You can set the default here..
I use just one template as my default.
Hi Melina -
One more thing to try…
Use the Reset command to make sure that any customization is not getting in the way here. If you have customizations that you would rather not lose, you can use the Save Settings for Support… button. Then use the Factory Reset option.
Hi Wim, I tried the Factory Reset as well, but unfortunately the template names are still invisible. The issue is still the same.
Could you think of anything else we can try to fix this? It’s really important to me to get this issue resolved, as I need to use Rhino for my projects and I’m worried about running into problems later.
