Missing plug-ins?
Dang same error with 6.28 :disappointed_relieved:
Hi - can you please run the Rhino SystemInfo command and copy-paste the result here?
Hi @wim, here’s the result. I might be simply missing a plug-in, but from googling and the docs here it sounds like a plug-in isn’t necessary.
Rhino 6 SR28 2020-6-23 (Rhino 6, 6.28.20175.14591, Git hash:master @ 9ddbd1399e001a3eae701470332b5379477fa7d6)
License type: Educational, build 2020-06-23
License details: Cloud Zoo. In use by: Lyrana ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: MININT-AGVERM5
Hybrid graphics system.
Primary display: Intel® UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 12-13-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 12-10-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 432.18
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-10-2019
Driver Version: 26.21.14.3218
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.28.20175.14591
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.28.20175.14591
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.28.20175.14591
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.28.20175.14591
STL export is a plug-in IIRC, can you check in Options>Plug-ins and see if it is in there and enabled?
Thanks for the move/split @John_Brock
Pasting my last reply here for visibility on this thread as well:
This was user error, I didn’t scroll down further to see the STL section, thinking that there was a naming convention as Export__<fileformat>
So I thought “yeah I have all the available plug-ins enabled” don’t see one needed for STL, error message must be wrong…Rather than scrolling down to the S section… smh
Anyone reading in the future, look for STL Export:
And you’re good to go!!
I’m so sorry! @wim the one thing I would ask though is that you add that to the docs page that I linked above?
Hi -
Pretty much everything in Rhino is a plug-in. I don’t think it would make sense to start the help page for each command by stating that.
Ah! I didn’t realize. :slight_smile: Got it, thanks for circling back around to reply.
