i have a problem with the Shapediver viewer. i use the gITF Display + material to give single meshes a color.
It worked fine in Rhino + Grashopper but not in Shapediver. Everytimes some meshes are missed. i try differnt ways but can not solve that problem. can someone please help?
You could check if you left the preview on for some components other than the Display components in your definition. Also check if you have internalized all your geometry.
I can help investigate the issue if you can create a minimal Grasshopper definition that you can share with me for debugging.
Thanks for your quick answer. Preview of all components is switched off.
please finde attached complete Grasshopper file RKP_Module_Cube_SK.gh (48.0 KB)
My apologies, I could not look at this issue yet. I noticed that you are using a JSON file and a 3dm file as input, which I would need to test the definition.
