Greetings,
I am attempting to hide multiple objects in multiple details within several layouts of a rhino file.
I have got a test script functions correctly, however I have had to use rs.Command(“_HideInDetail”).
The problem is, my current method takes a long time to hide large numbers of objects across several layouts and details. I assume there must a way to gain access to the HideInDetail functionality without using the Rhino command line, but I have not been able to locate it in the docs.
Any assistance would be extremely helpful, below is my test code complete with command line functions.
Thanks
import Rhino
import scriptcontext
def HideInDetails(Objs):
for layout in scriptcontext.doc.Views.GetPageViews(): #Get all layouts in document
scriptcontext.doc.Views.ActiveView = layout #Set layout to active view
for detail in layout.GetDetailViews(): #Get all detail in each layout
if detail.DetailGeometry.IsProjectionLocked==True: #Test if deatil is locked
detail.DetailGeometry.IsProjectionLocked=False #Lock detail so we can edit it
detail.CommitChanges() #Unlock the detail
layout.SetActiveDetail(detail.Id) #Set detail to active
## Would like to accomplish this in rhino common ##
rs.SelectObjects(Objs) #Select Items we dont want to see in detail
rs.Command("_HideInDetail") #Hide everything you dont want to see in the detail
rs.Command("_SelNone") #Clear selection
objs=rs.GetObjects("Select objects to hide in all details")
if objs: HideInDetails(objs)
If you just do this manually, using the HideInDetail command, does it (also) take a long time? If so, re-writing the command in RhinoCommon isn’t going to speed things up…
Dale,
Thanks for the quick reply. I did a quick test to check which operation was taking the most time and it was the selection command which selects the objects before HideInDetail is called. After modifying the script to add in a couple timers it came back with the following results:
Number of objects:1
HideInDetail timer: 0.124786376953
Select objects timer: 0.0935897827148
Number of objects:8
HideInDetail timer: 0.0780029296875
Select objects timer: 0.639625549316
Number of objects:27
HideInDetail timer: 0.109191894531
Select objects timer: 2.21517181396
Number of objects:64
HideInDetail timer: 0.093620300293
Select objects timer: 5.47750091553
Number of objects:125
HideInDetail timer: 0.10920715332
Select objects timer: 11.8618316650
Number of objects:216
HideInDetail timer: 0.187973022461
Select objects timer: 23.8121566772
Number of objects:343
HideInDetail timer: 0.313987731934
Select objects timer: 35.6105422974
As you can see the amount of time spent waiting for objects to be selected is much greater with higher object counts while the time spent waiting for all the objects to be hidden is minimal. This makes me think that if I could pass the object guids directly into some sort of HideInDetail function without having to select them it would speed up this process.
Thanks,
5chmidt
s_timer=0
h_timer=0
start=time.time() #Start selection timer
rs.SelectObjects(Objs) #Select objects
end=time.time() #Stop selection timer
s_timer+=end-start #Record selection timer
start=time.time() #Start hide timer
rs.Command("_HideInDetail") #HideInDetail
end=time.time() #End hide timer
h_timer+=end-start #Record hide
print "Number of objects:"+str(len(Objs))
print "HideInDetail timer: "+str(h_timer)
print "Select objects timer: "+str(s_timer)
print
Yes, turning off redrawing helps, in the past I tend to have unexpected things happening when I turn off redraw when using command line functions. In general I have tried to avoid it, but in this case it seems to work fine.
Dale,
For this example it is not necessary, but if it is possible, I would be interested to know how to HideInDetail using Rhino common rather than having to call a command line function.
Thanks,
5chmidt
How would one addhidedetailoverride in a python script?
Sorry learning python atm and making automation for architecture manufacturing processes. Aiming to select object, create new layout, create detail, isolate object in detail, create top,front,side section views of object and automatic dimension them. Big task.
You might consider creating your objects on different layers and then turning layers on/off in details using Layer.SetPerViewportVisible. A “better” organizational approach than hiding objects in details.
Thanks Dale, The only issue is doing shop drawings when you isolate a select part. The part would normally be on a layer with a collection of similar parts. Having a layer per part becomes to hard.
Also, I am struggling to toggle the attribute addhideindetailoverride
Could you please give me a short example. This is what i am using now:
import Rhino
import scriptcontext as sc
def TestHideInDetail():
page_view = sc.doc.Views.ActiveView
if not isinstance(page_view, Rhino.Display.RhinoPageView):
print('The active view is neither a layout nor a detail view.')
return
detail_view = page_view.ActiveDetail
if not detail_view:
print('The active view is not a detail view.')
return
viewport_id = detail_view.Id
filter = Rhino.DocObjects.ObjectType.AnyObject
rc, objrefs = Rhino.Input.RhinoGet.GetMultipleObjects("Select objects to hide", False, filter)
if rc != Rhino.Commands.Result.Success:
return
for objref in objrefs:
obj = objref.Object()
if obj:
attributes = obj.Attributes.Duplicate()
attributes.AddHideInDetailOverride(viewport_id)
sc.doc.Objects.ModifyAttributes(obj.Id, attributes, False)
page_view.Redraw()
if __name__ == "__main__":
TestHideInDetail()
