Missing feature - Detail View of CPlane Ortho Views etc
When creating views used in Layouts, there is not implementation of CPlane ortho views. Therefore certain things are impossible.
In image, see views created for the Layout Space.
This is done using command Detail:
Implementation only provides “Projection=Top” and the other preset WCS projections. If the geometry is rotated, then doing a ortho view of it and placing it on the Layout is impossible. Which is quite cumbersome in certain cases …
Please implement custom Cplane (Ortho + Arbitrary Perspective etc) Views.
Thanks
/Erik
Here is a more visual description:
Building is placed like this when viewed from the top (wcs).
See the bright green cutting plane.
Geometry cut according to custom depth enabled in Perspective mode.
Ortho View of Cplane aligned to the building.
Now the problem. This view IS NOT possible to get onto a Layout as far as I understand as there is no way of saving it to the “Views Clipped” Layout Space.
Please fix this.
Thanks
/Erik
