Hi, I am missing these components and I am using a Rhino 7. Can someone please help me?
“Kangaroo Components” refers in my opinion to an earlier version of Kangaroo. Rhino 7 out of the box comes with a new version that also includes the Combine&Clean and WarpWeft components. Simply substituting the legacy components for the newer ones should do the trick.
Mesh Pipe is a component that comes with the MeshEdit add-on. It’s old at this point and hasn’t been updated for some time, but it should still work fine. It probably needs to be installed manually (not via PackageManager
A newer version of TT Toolbox can be installed from PackageManager
. You might again have to replace the old components with their newer versions.
