Missing command Rhino 8
Hey there,
after upgrading to Rhino 8 i miss a command, not in the tool bars, but in the command line. Missing command is “Parallelkurve”. Any ideas?
Hey Christian -
What are you upgrading from?
Can you post a screenshot of the toolbar that has this command?
Try “Versatz”…
This is an issue I have always had with the German translation - specifically the button tooltip - of Offset… @Joachim_Kuntz
Command line: Versatz (literally offset)
Underscore English version:
Menus:
Button tooltip:
Why???
We’ll qiute easy, thanks for!
Good question indeed: why is it still there??? I truly believed I had eliminated all occurences of Parallelkurve(n). And here we are again.
Thanks for pointing it out, I’ll dig into it as soon as I can.
When we are at that…
…what about Parallelfläche?
The next menu item is …versatz.
@Charles
Versatzfläche?
Vielleicht Flächenversatz, wie bei Variabler Flächenversatz?
Yep.
Fixed. From the next build on it should be:
  • Parallelkurve => Versatzkurve
  • Parallelfläche => Versatzfläche
There might still be traces in the documentation, e.g. the user’s guide. I’ll clean them out as well, when I get the chance.
Autodesk and PTC also use the term ‚Versatzfläche‘
Good to know.
In the 90s of the last century I used a German CAD (PC-Draft).
Then I had to fiddle with AutoCAD, and I couldn’t find the function for parallel curves.
I had to ask someone… the answer was, of course, Offset.
In non-CAD usage “Versatz” is a different position of an element.
If you apply a "Versatz" to a car you don’t get a bigger or smaller car.
I very understand the OP’s question.
