Missing Bullet Points?
Hello All,
I’ve just switched back it Rhino 6 hoping that it’s at the stage that I can start producing construction drawing from it. One thing that still appears it be missing is Bullet Points in text. They are probably in there but I can’t see them. I always used to get by using ALT code text in Rhino 5 (which is incredibly useful for many situtations) however the ALT codes no longer work!
I guess, the questions are
1.) Are there Bullet Points? , 2.) Will ALT Codes be continued into Rhino 6 ?
Many thanks,
Paleblue
Yeah, this has apparently been removed or there is a bug somewhere.
Alt+0149 makes a bullet in V5, but nothing in V6. It shows up when you type it in the text box, but disappears once you hit OK. You can copy/paste from text containing it V5 into V6 and you see it onscreen, but if you try editing the text, it disappears again…
Most of them do appear to work here except bullets. There is Alt+0183, but it’s not very bold.
–Mitch
Do you know if there a plan to fix this?
Dunno… @lowell?
I’ll see what I can do.
Fantastic
Cheers :slight_smile:
RH-42914 is fixed in the latest BETA
