Mirroring curves not previewing in correct place
Mirror line taken at midpoint of straight curve. Curve (a trimmed circle) displays in the wrong position (yellow curve).
The points are in the correct place. When command is excecuted the mirrored curve appears in the correct position.
Rhino 6
You are very far from the origin in Y - 143,000+ units. I can repeat this at that distance under certain circumstances - I actually get no preview at all in the file at a certain point. Nearer to the origin it’s OK.
In the file below at about 130,000 units in X, mirroring the green arc around the center of the box (line) gets a preview. The red arc, 10 units further to the left, doesn’t.
MirrorNoPreview.3dm (309.2 KB)
–Mitch
Is this just a Rhino 6 problem? I have never had trouble with this in the past.
Yes, it works fine in V5. @stevebaer This appears to be another side effect of “GPU Tessellation”. If I turn it off here the preview is correct.
Bug filed: https://mcneel.myjetbrains.com/youtrack/issue/RH-44199
@benjamin can you post the file with the elements in your image? I can’t make it happen here in Y, only in X.
–Mitch
If it helps
mirror-curve-test.3dm (278.5 KB)
Got that. thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44201
Hi @benjamin,
So far, I am unable to reproduce the in correct preview image that you’ve reported. My test box even has a lame gpu (Intel).
Can you click Help > System Information and copy/paste the results into a reply. Also, the sample file you posted doesn’t seem to have the geometry you’ve presented in your original post. Is that something that is available?
Thanks,
– Dale
Rhino 6 SR1 2018-2-6 (Rhino 6, 6.1.18037.13441, Git hash:master @ 5a33e6871b94d32ba552468218cef0ad8d3d1263)
Windows 8.1 (Physical RAM: 16Gb)
Quadro K1100M/PCIe/SSE2 (OpenGL ver:4.4.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
mirror-curve-test2.3dm (227.6 KB)
Now the mirror preview doesn’t display at all.
Thanks @benjamin, I’ve logged your info on the YouTrack item.
– Dale
I (as well as a few co-workers) have had the same issue with Rhino 6. We’re getting some mis-located previews with various transformation commands: rotate, move, scale1d, etc…
If I can provide information on my machine/install/files that would help out with this, please let me know.
@dale here’s mine -
Note this is happening on two computers, one with a 980 Ti, the other (below) a 780.
@pascal - I think you duplicated my yt entry…
Rhino 6 SR2 2018-2-7 (Rhino 6, 6.2.18038.4101, Git hash:master @ a558313bc402d40d17bdf4500977c08ab6e465e4)
GeForce GTX 780/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 390.77)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-23-2018
Driver Version: 23.21.13.9077
Total Video Memory: 3 GB
Any news on this?
According to youtrack, it does not appear to have been worked on yet…
