@pascal I’m in the latest SRC for Rhino (7.24.22297.11001, 2022-10-24) and History updates on this _FlowSrf Rigid=Yes with subsequent mirroring is bugged. The initial flow and mirror are correct, but I am unsure how history is recalculating.
I tried to recreate this with only the mirror, but it’s only bugged when FlowSrf is involved. I move a lot of complicated history stuff to a corner with _FlowSrf Rigid=Yes, so I don’t clutter my workspace.
I’m sorry it’s so complicated. I spent an hour trying to simplify the setup, but it only happens with all of this in place. If you edit those Default::EditCrvs’ children on Default::DoNotEditHistoryStuff the bug dissapears.
@pascal, I have some new info. I remade this from scratch, and it worked fine. Then I realized I missed one step. I went back and remade it from scratch again, and the problem returned. These curves made via a gumball transform (gumball copy down 5 mm aka _Copy -100,100,30 -100,100,25) seem to be involved.
curve
Object name: (not named)
Layer name: Default::DoNotEditHistoryStuff
Render Material:
source = from layer
index = -1
Groups:
Group17
Attribute UserData:
UserData ID: 563238F9-C201-411d-A7B1-13895A0317AD
Plug-in: Rhino
description: AutoPointsOn
saved in file: no
copy count: 1
UserData ID: 0D007E84-79CC-4b4a-850B-C23EF2CEC640
Plug-in: Rhino
description: Hide user data
saved in file: yes
copy count: 137
Geometry:
Valid curve.
Line
start = (-97.053 millimeters,100.000 millimeters,24.182 millimeters)
end = (-97.053 millimeters,104.105 millimeters,24.182 millimeters)
domain = 0.000 to 1.000
line length = 4.105 millimeters
History:
Record index: 6
Record id: 17C31E7B-1DCE-4554-95A6-5741C20649BC
Command: Transform
curve
Render Material:
source = from layer
index = -1
Groups:
Group17
Attribute UserData:
Plug-in: Rhino
saved in file: no
copy count: 1
Plug-in: Rhino
saved in file: yes
copy count: 6
Geometry:
Valid curve.
Line
start = (-97.728 millimeters,105.023 millimeters,24.182 millimeters)
end = (-100.000 millimeters,105.023 millimeters,24.182 millimeters)
line length = 2.272 millimeters
History:
Record index: 7
Record id: 333AAB8A-4F3D-479a-A87C-6D5272C93BFC
Command: Transform
I do that little copy-down trick for visibility purposes. I like for my editable crvs to hover over the shape I’m trying to trace/match.
I made four different versions of this angle bisector today. It worked 100% of the time when I swapped my normal copy-down transform with the _Flow base crv adjustment.
