Mirror Command
I forget whether or not there is a way to Mirror an object and have the mirror entity move as you move the original. Is that a thing in Rhino?
Thanks,
Thomas
If you have History enabled when you do the Mirror operation, then it should behave that way. Also make sure the history setting “Lock children” is not enabled.
thank you so much. I’ll try that now.
Thomas
