I notice that the minutes from last save on the status bar is not updating when a file is saved.
Thanks,
Dan
It seems to be related to saving back to Rhino 7. I tried again saving to Rhino 9 and it works as expected.
Thanks,
Dan
Same behavior in Rhino 8. Rhino appears to consider SaveAs to a previous .3dm version to be essentially exporting everything rather than saving with a different name. Rhino behaves the same as if the SaveAs file type was other than ..3dm (.stl or .igs for example).
Note that if you SaveAs to a previous .3dm version the name of the active file in the upper left corner remains the same as it was before the SaveAs. Subsequent Save will overwrite the retained active file, not the more recent file with the previous file type from SaveAs.
