Thanks for the swift reply.
On the change layer colour, clicking a colour swatch opens the Select Colour dialogue box (and shuts the dropdown Layer panel) and after selecting a colour and clicking Apply the box shuts, but nothing has changed. The Right Sidebar functions fine.
On the help files, I’d only tried one. I just tried some others and they work fine. The one that functions as I described was the entry for Enter. In it, it has two blue Enter links, they both do it.
I’ve just revisited the Animation and this time had it save the file to Downloads, it worked fine. I guess it worked the first time, but I can’t find it.
While I have your attention. Is it possible to make a SpaceMouse button function as Return? It used to work (V5 and V6) but it now states in the help file (hence I found the funny Enter link) “The Enter command does not repeat the previous command like pressing the [Enter] key does.” am I missing something?
Again, thanks for the reply.
Rhino 7 SR0 2020-11-9 (Rhino 7, 7.0.20314.03002, Git hash:master @ 9d1a3d02b292e00d3480c301d33f414d91acdcbd)
License type: Commercial, build 2020-11-09
License details: Stand-Alone
Apple Intel 64-bit macOS Version 10.16 (Build 20B29) (Physical RAM: 8Gb)
Mac Model Identifier: Macmini8,1
Language: en-GB (MacOS default)
Intel® UHD Graphics 630 (OpenGL ver:4.1 INTEL-16.0.49)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel UHD Graphics 630
Displays: DELL U2415 (94dpi 1x), DELL U2415 (94dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
DELL U2415 (1920 x 1200 @ 59Hz)
USB devices
GenesysLogic: USB3.0 Hub
Maltron: USB Keyboard
3Dconnexion: SpaceMouse Wireless
GenesysLogic: USB2.0 Hub
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
Broadcom: Magic Trackpad 2
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20314.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20314.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20314.3002
