The ArrayLinear command cannot take 0 (zero) as its first reference point. (0 is a shortcut for 0,0,0.)
Hi Andrew - yeah- the command is currently set up to accept an integer to change the count of objects, but of course 0 makes no sense and should be accepted as the origin - this is possible inside GetPoint so I’m pretty sure this is an easy fix - thanks for the report.
https://mcneel.myjetbrains.com/youtrack/issue/RH-36058
