I have inadvertently gotten the Layers column widths in v7 so wide that I cannot see the ones I need to be able to access to select, i.e. Name, Current, Locked, etc. What is the solution?
Thanks in advance.
David
Thanks in advance.
David
Pls try to turn off and turn on the “ON” options of the Layer? fyi and hope it works to you.
Hi Jessesn.
Thanks for your reply.
It’s not the Layer States panel.
It’s the Layers panel in which all layers exhibit the problem.
That had no effect.
Hi David -
You can simply drag the divider in the column headings to change the width of those columns.
I know that Wim, it’s an unsatisfactory process. I tried doing that for hours yesterday and am still trying to.
~ David
Hello again Wim. My mistake(s)!
I was “simply” dragging the divider, starting with the one between Lock and Color to the right. I just now discovered I should have been dragging the dividers to the left and that solved my issue.
Thanks again,
~ David
