I would like to minimise this window and carry on working in Rhino - will this be possible ?
Thanks,
Thanks,
Hi @KeithR,
Technically it is possible, but currently the RenderWindow is modal, so while the rendering is in progress it blocks other usage. I have open RH-39660 for this.
/Nathan
Can you make this accessible to the general public?
Any better now?
Yup! Thanx (:
3 posts were split to a new topic: View capture restarts Raytraced
On my machine. Should be in next public WIP release. Not showing here, but you could minimise the window if you wanted to
@nathanletwory would multiple render windows also work ? setting up different angles to render out.
K.
With this change the RenderWindow is no longer blocking, so you can start as many as your hardware allows you to:
Works great @nathanletwory, thanks for your time.
Keith
Enjoy (:
