Hi, I don’t often use the turntable command, but when i do I never use it at default 50 since that is very fast, so could you please just lower the default to 15 or something?
I mean, the point is to pan slowly around an object for inspection, so a slow pace would be better IMO
Yes, you can, but it is not intuitive.
(And you are typing in the dark, so easy to misspell if you want fullscreen to run in full fullscreen mode with no command line)
