I’m following the migration guide for the Viewer from v2 to v3. It works well for sample models as provided in the code snippets but doesn’t work with our setup. Now I narrowed down the issue into one component which might causes the problem.
The TextFileInput
component is used in our model and worked well for the last 6 months. Now, when moving to v3 it seems that the input field is not working properly. Since you still provide settings/viewer for v2 I was able to use the input field in the dashboard. This shows clearly that in v2 the file input is working, while in v3 it doesn’t. Please see below.
My model is private but the model name is: Giltek lattice tower v1.2
and the url to that shapediver.com/app/m/giltek-lattice-tower-v1-2
Could you please take a look what is the issue?
Env:
- MacOS Big Sur v11.5.2
- Rhino Version 7 (7.14.22010.17002, 2022-01-10)
- Grasshopper 10/01/2022 version
