Migrate.exe crash
I try to migrate my plugin from Rhino5 to Rhino6.
I call the tool “migrate.exe” you provided and “migrate.exe” crashed.
Noname0
Noname
Why?
Help me to fix the problem.
Kind Regards,
Vaker
Hi @Vaker,
Do the manual migration instructions work for you?
– Dale
Hi Dale,
I will try manual steps.
Thank you
Kind Regards,
Vaker
Hi @dale ,
When I finished all manual steps, I still compile failed.
ON::display_mode CRhinoObjectManager::GetRhinoDisplayMode()
CRhinoView *view=RhinoApp().ActiveView();
return view->Viewport().DisplayMode();
How to change for Rhino 6?
Is there any document which is descriptions of details for Rhino5 migrate to Rhino6?
Vaker
What is the compile error?
Hi @nathanletwory ,
The compile error as below:
SP173110-05
Vaker
ON::display_mode no longer exists. To get the display mode of the active view you ask on the CRhinoViewport for its ON_3dmView (through View()) and from it you get m_display_mode_id. This ID you can compare against members of ON_StandardDisplayModeId.
Note that in your code you also should use ActiveViewport() or MainViewport() instead of the deprecated Viewport().
CRhinoView *vw = RhinoApp().ActiveView();
ON_UUID dispm_id = vw->ActiveViewport().View().m_display_mode_id;
bool is_rendered = ON_StandardDisplayModeId::Rendered == dispm_id;
Note that you can use ToV3DisplayMode on ON_StandardDisplayModeId, that gives you a ON::v3_display_mode, which corresponds to your old ON::display_mode case.
Hi @nathanletwory,
Thanks for your help.
I changed code as you say and fixed the compile error.
I have another error as below:
The function “EnableGhostedShade()” is undefined.
SP173110-11
Vaker
@Vaker, sorry, I don’t know what happened to EnableGhostedShade(), I’ll let @dale answer that one.
Hi @Vaker,
Try this:
pView->ActiveViewport().SetDisplayMode(ON_StandardDisplayModeId::Ghosted);
– Dale
Hi @dale,
How to switch enable or disable ON_StandardDisplayModeId::Ghosted?
There is another similar error:
How to switch enable or disable XrayShade?
void CRhinoObjectManager::SetGhostedShade(bool bGhosted, ON_UUID disp_mode)
CRhinoView *view = RhinoApp().ActiveView();
view->Viewport().SetDisplayMode(disp_mode);
view->Viewport().EnableXrayShade(false);
view->Viewport().EnableGhostedShade(bGhosted);
view->Redraw();
Vaker
Hi @Vaker,
I’m assuming this:
pView->ActiveViewport().SetDisplayMode(ON_StandardDisplayModeId::XrayShade);
Will switch to XrayShade (and disable others).
-David
Hi @DavidEranen,
I will try it.
Vaker
