Micro problem when snapping a container on the edge of screen
When in windows the Rhino window is full screen (as usual, not rhino _fullscreen mode), I want to snap the OSnap container to the left bar (as where it is by default in R8), the UI snapping mechanism goes crazy.
I suspect its because of two monitors, the other on the left. Seems like as I am dragging the osnap container to the left bar, close enough to the edge of the screen and it goes crazy. It starts circling where to snap to rapidly. Resulting into not being able to snap anywhere on the left side.
The solution is to minimize the Rhino window to a smaller size. Then it works fine.
Rhino 8 does not have this problem with the same setup. The Rhino file does not matter.
Maybe its not even a Rhino issue but i just wanted to let you know, thanks.
Rhino 9 SR0 2026-10-6 (Rhino 9 BETA, 9.0.26279.06303, Git hash:master @ 38442ba6302a687894bfeb92efd4dd088e13993d)
License type: Commercial, build 2026-10-06
License details: Cloud Zoo
Expires on: 2026-11-20
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.12
Computer platform: DESKTOP
Standard graphics configuration using DirectX
  Primary display: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 7-22-2026 (M-D-Y). DirectX(11)
Secondary graphics devices.
  Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 10-13-2021 (M-D-Y).
        - There are no monitors attached to this device!
DirectX Settings
  Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
  C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp	"Commands"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp	"RhinoAI"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp	"3DxRhino.9"
  C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp	"UpdatesAndStatistics"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp	"MeshCommands"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	9.0.26279.6303
  C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp	"SectionTools"
  C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp	"AnimationTools"
Hi @Jakub_Dobrovolný,k
I’ve logged a ticket so a developer can investigate.
Thanks,
– Dale
