Hi there,
Do any of you know of a way/addon to create .cli files with Grasshopper? We need .cli files to transfer the data to our laser sintering system.
[COMMON LAYER INTERFACE (CLI) (hmilch.net)](COMMON LAYER INTERFACE (CLI))
The reason why I am asking is the following: With Axolotl you can directly generate a slicing based on a “distance object” without having to generate a mesh first.
Especially when creating complex components with lattice structures, .stl files are generated that often require several hundred MB if not GB of memory. Even within a GH definition for creating a geometry based on a volumetric approach (e.g. with Axolotl, Dendro, Isopod in GH1 or Kampecaris in GH2), the conversion to a mesh takes most of the time.
If I remember correctly, this function is integrated in nTop. If this were also possible with Grasshopper, you could save a lot of money
-Kevin
Volumetric Slicer V1.gh (109.6 KB)
