Meshing problem
Hi, I have a problem related to meshing a nurbs surface with many trims. In attached 3dm if I mesh the surface present in layer “srf” with the mesh parameters reported in attached image I obtain a wrong triangulation. The mesh obtained is on layer “mesh”. As you can see inside holes there are wrong triangles. If I change the Maximum edge to surface distance to 0.01 mm the problem disappear.
wrong_mesh.3dm (16.4 MB)
Hi @Gabriele_Cuccolini,
Thanks for the file. A few observations:
  • The surface in the file is planar, so Density and Maximum angle don’t affect it. On a flat face, the mesh comes from the trim curves (here, 1,200 holes) together with Maximum edge to surface distance and Maximum aspect ratio.
  • With your settings, setting Maximum aspect ratio to 0 gives a clean mesh and still keeps your 0.002 mm tolerance. It also produces far fewer triangles: about 145,000 instead of about 460,000.
  • As you found, raising Maximum edge to surface distance also works. 0.005 mm and 0.01 mm both produce clean meshes here.
What will you use the mesh for (rendering, STL for printing, FEA, CAM, …)? If something downstream needs a specific accuracy, tell us what it is and we can suggest settings for it.
Thanks,
– Dale
Hi Dale, thanks. I’m using this mesh for CAM applications but 0.01 mm will be good. In any case do you think that this bug will be solved in Rhino 9?
bye
A bug, a limitation - I’ll let you decide.
And no, Rhino 9 will not solve this.
– Dale
