I tried the triangulate mesh option but it only divides the mesh into 2parts.
Also i want to convert the mesh to lines so that it can be set as input it into the software.
Hi @KARHI
Look at the attached video - just use the detailed controls of the Mesh command and uncheck Simple Planes + Refine Mesh and set the Max Edge Length to your liking, then run TriangulateMesh.
Or if you are starting with a simple mesh surface, run Subdivide until you have your desired level of detail, then run TriangulateMesh.
Or you can rund QuadRemesh on whatever geometry you’re starting from and then TriangulateMesh.
There are probably more ways to get there…
