Meshes from scanner data
I’m just looking at Rhino 7 and I was wondering. These meshes that are created from scanner data is very dense and of course, you have to be in the render display to see the mapping of the bitmaps that are applied to the mesh, (if it has bitmaps and not grey scale). But the problem is. With these meshes, when you select them in Rhino, all the normal information gets very obscure. Here is before selecting the mesh and after.
As you can see or not see, all the detail of the mesh is lost when the mesh is selected. What I propose is do something similar when using Mesh/Edit Tools/Extract/Faces.
As you can see, the mesh is very clear and would make it so much easier to visualize or manipulate what’s selected instead of seeing a solid color with no detail what so ever, don’t you think?
Thanks for viewing my request.
Have you tried ‘Shade-highlight selected meshes’ ?
Perfect!
Thanks for clicking the solution button
