The screenshot above shows road surfaces with lane markers getting cut into them, and while the original surface was made in 7 for PC (quad remesh) the parts showing triangles at the edges were reimported from 5 into 7
This is not a major concern for the project but if I am using the Mac for some work as well, it would be nice to keep the mesh wires as clean as possible
Is this just a feature that 7 automatically address / omits (triangulated edges)? Is there a way to change the export or rework the mesh in 7 to return to the quad state?
I’m not sure if it would make a difference but it was nice on the original quad mesh (before being mesh split into roads and landscaping) to be able to push and pull the vertices in Max to quickly edit the terrain
Because of this background - my guess - you will not find a satisfying workflow combining Mac-Version 5 (that is missing many functionality compared to V5 PC) and Version 7.
In this image, the original mesh and curves are at the top left. At the top center, the mesh is split with CreateNgons=Yes, while at the top right, this option is set to No. As to your question, there is a AddNgonsToMesh command that I used to get the bottom right outcome. As you see, the result is not the same as using CreateNgons=Yes during the split operation.
As Tom mentioned, why not use Rhino 7 on your Mac as well?
Thank you for the detailed responses - I’m using a 2011 MBP from school (which is still surprisingly alive and kicking) to squeeze in some more hours of work, and of course, the OS update limitations, planned obsolescence etc. etc. The machine and R5 are handling the larger file sizes admirably however
At this point, if it does not impact the render quality then I will move ahead - noted about the quad remesh and the ngon methods - thanks again for the suggestions! Will refer back with results as they arise
Is there a way to best preserve boundaries for an open mesh when using Quad Remesh? Also, if I were looking to push and pull mesh vertices in Rhino like in 3ds Max, is there a way to do so?
It’s recommended to start new threads when asking questions that are not 100% related to the original topic.
The Detect Hard Edges should do that. If you have a case that is not working as you expect, please post a 3dm file in a new thread.
I have no idea about 3ds Max. In Rhino, you can enable the “soft transform” mode by running SoftTransform and setting a radius and shape. When you then select a mesh or SubD vertex (or vertices) and move this, the surrounding vertices within the radius will be affected.
