Mesh vertice points are wrong
hello
i was trying to connect mesh vertice points to some other points and was getting funny lines. so i checked and realized vertex point list numbers are wrong as seen in the picture. if i use the same shape as a surface this problem disappears and numbers and lines are correct.
what may be the reason ?
Hi :slight_smile:
It’s not necessarily wrong. The vertices of a mesh does not have to be in geometric order. What do you mean by funny lines?
what i wanted was “pramid” like diagonals between vertices and polygon centers instead i got what is in the picture
Umut, the most simple way to do this is with Weaverbird.
The Stellate component add a pyramid on every mesh face.
In case that doesn’t work for you, post a Rhino file and Grasshopper definition with the relevant inputs.
i will share an example of desired vs what i got
this desires result i can obtain by using surface commands instead of mesh. because surface vertices are “in order”
pic i shared before is the obtained result from mesh
this pic is obtained by surface usage
If you want help, please post your files instead of just screenshots.
FULL_OTOMASYON_UZAY_2.gh (23.6 KB)
here is the file with internalised surface and mesh
I don’t use Pufferfish so I can’t see what you’re trying to solve with some of the components.
You can use Extrude to Point to create the pyramids.
FULL_OTOMASYON_UZAY_2.gh (22.1 KB)
thanks martin, i tried your solution on the mesh side of the code and it worked
