Mesh Vertex Selection
Hi
I am driven by need to select certain groups of points in a quad mesh.
i want to establish a rules upon which i can select the number of U rows and V rows and get back only the points corresponding to this coordinates.
i am almost where but the logic work only when i select 1 single index for u or v.
I want all points laying on these curves
In u it works only if there us a single index
if there are 2 or more index it fails
in V also fails
how can i get all points coincident with the selected curves ?
thanks
20260925 mesh vertex select.gh (20.0 KB)
20260925 mesh vertex select VR 3.gh (19.3 KB)
Many thanks @Volker_Rakow ,
this was not exactly what i needed but it brought me back on the right root, working with list of point was much more convenient that using reference curves + curve-point distance fri selection.
here is what i came out with. many thanks
20260925 mesh vertex select 02.gh (117.0 KB)
I don’t have your plug-ins. I don’t know what this does.
Hi @Volker_Rakow ,
above definition was just a part of a bigger script, ( its all vanilla GH ) …the goal was to be able to select all points laying on choosen ( by acting on “points selection” inputs ) u and v curves..
Your suggestion was crucial because it showed me the way to go ( by using index rather that by using curves and select by measuring distance form curves )
BTW i want to thank You for showing me how to use the metahopper setslider component…that is really useful.
cheers
