Mesh vertex normals list
Hi all,
how can I convert the MeshVertexNormalList to a List of Vectors?
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_Collections_MeshVertexNormalList.htm
I just can found the .ToFloatArray() method.
Is there a more direct way?
Thanks!
Hi @Baris, in case of a python script, you could try below:
import Rhino
import scriptcontext
import System
from System.Collections.Generic import List
from Rhino.Geometry import Vector3f
def DoSomething():
    mesh_id = rs.GetObject("Mesh", 32, True, True)
    if not mesh_id: return
    mesh_obj = scriptcontext.doc.Objects.FindId(mesh_id)
    normals = List[Vector3f](mesh_obj.Geometry.Normals)
    print type(normals)
DoSomething()
it should give you one List[Vector3f].
_
c.
Thanks for the answer ill give it a try.
Probably my initial problem requieres another approach.The Mesh thing is still kind a new for me.
Screen%20Shot%20082
NOTE: Prior asking for Normals you sould compute them.
NOTE: M.Normals indexing is acc M.Vertices indexing that IS NOT the same with M.TopologyVertices indexing. Prior doing anything with meshes resolve this 100% in your mind.
BTW: The attached can shed some light on Normal matters (what exactly is a vertex Normal? is it a bird? is it a plane? is it the Superman? etc etc)
Mesh_NormalsHowToCompute_V1.gh (11.0 KB)
Hi Peter,
thanks for the example. It´s nice to study with.
Regards Baris
