Is it possible to convert a mesh to a terrain object?
I have a scanned mesh I like to use as terrain.
Any suggestions?
Mario,
Any suggestions?
Mario,
Hi Mario, you can tag a mesh, a surface or other object as a terrain, from the Lands Edit panel.
This will make the plant species detect that object as a terrain and they will be placed on top of its surface. but the mesh won’t have the same features as a Lands terrain (contour curves, option to add paths, cuts and fills, calculate volume of earth moving, etc…)
There is a way to get a Lands Terrain object from one or more meshes in few steps:
Though, a scanned mesh can be composed of hundreds of thousands of points, if you create a Terrain from it the Terrain operations will be quite slow.
Perfect, Albert, that does the job.
Thnx!
