Mesh to Indexed Point, and Indexed Line lists?
Hi…,
sorry I am a Grasshopper dummy. :wink:
Is there a GH-program to get an indexed point, and indexed line list from a mesh (without double points and lines), like this:
List of Point-Arrays [Point Index, x, y, z]
[0, 14.5, 17.5, 5.5],
[1, 12.5, 3.0, 7.5],
[2, 17.5, 1.5, 99.5],
[3, 37.5, 21.5, 9.5],
List of Line-Arrays [Line Index, Start-Point Index, End-Point Index]
[0, 0, 1],
[1, 0, 2],
[2, 0, 3],
[3, 1, 2],
[4, 1, 3],
Thanks
Michael
www.flexiCAD.com
Network from Lines by Heteroptera for example
In case that you are familiar with coding (or you have future plans to do that):
7 out of the 9 possible Mesh connectivity Trees (related with topology vertices (TV) - Note: not vertices, topology edges (TE) and faces (F) => 3*3 = 9 combos) are directly doable via SDK Methods (and the rest 2 are not nuclear science) : meaning that is very easy to do what you want (or any imaginable TV, TE, F info combo [as List in a Tree or a custom class properties etc etc]).
Notify if you need a C# example on that.
Hi @Jakinta and @PeterFotiadis,
thank you for your feedback.
I am familiar with JavaScript, a little with Python, and dragging some components in GH.
I didn’t want to spend too much time by digging in new languages or testing unknown GH components.
Thanks
Michael
Hi scripters,
I’ve written now a python script to get my lists in JSON format:
mesh: {
point: [
  { id:   0, x:   -6.9694, y:    9.2147, z:    0.0000 },
  { id:   1, x:   -7.3193, y:    2.6245, z:    0.0000 },
  { id:   2, x:   -0.6124, y:    2.9161, z:    0.0000 },
  { id:   3, x:    1.0206, y:    8.8065, z:    0.0000 },
  { id:   4, x:    4.5199, y:    1.3414, z:    0.0000 },
  { id:   5, x:    6.9694, y:    7.6984, z:    0.0000 },
  { id:   6, x:    5.4530, y:   12.9473, z:    0.0000 }
line: [
  { id:   0, a:   0, b:   1 },
  { id:   1, a:   1, b:   2 },
  { id:   2, a:   2, b:   3 },
  { id:   3, a:   3, b:   0 },
  { id:   4, a:   2, b:   4 },
  { id:   5, a:   4, b:   5 },
  { id:   6, a:   5, b:   3 },
  { id:   7, a:   6, b:   3 },
  { id:   8, a:   5, b:   6 }
It converts all quads and tris of a mesh to point and line lists without double entries. Here is the python script, if someone needs it: mesh_to_point_and_line_lists.py (3.3 KB)
Thanks
Michael
www.flexiCAD.com
Hi…,
if someone is interested, I have written another version which writes normals, vertices, and faces of a mesh to JSON: 20200416_mesh_normals_vertices_faces_to_JSON.py (3.7 KB)
The JSON looks like this:
mesh: {
normals: [
  { id:   0, x:   -0.2173, y:    0.0345, z:    0.9755 },
  { id:   1, x:    0.0000, y:   -0.0000, z:    1.0000 },
  { id:   2, x:   -0.0497, y:   -0.2668, z:    0.9625 }
vertices: [
  { id:   0, x:   -7.3193, y:    2.6245, z:   -1.6390 },
  { id:   1, x:   -0.6124, y:    2.9161, z:    0.0000 },
  { id:   2, x:    1.0206, y:    8.8065, z:    0.0000 },
  { id:   3, x:   -6.9694, y:    9.2147, z:   -1.6390 },
  { id:   6, x:    5.4530, y:   12.9473, z:    1.3766 }
faces: [
  { id:   0, normal:   0, v0:   0, v1:   1, v2:   2, v3:   3 },
  { id:   1, normal:   1, v0:   1, v1:   4, v2:   5, v3:   2 },
  { id:   2, normal:   2, v0:   2, v1:   5, v2:   6 }
Take care
Michael
