Mesh Surface Make Polysurface
A script that converts a mesh surface to polysurface or surface is required. Can you help me with this? Mesh surface can not polysurface.
Do you want a result similar to subd to nurbs conversion?
Yes, if possible. Because I’m going to do the calculations using surfaces. Also the mesh surface at maxsurf does not work. He needs a smooth surface. I do mesh to nurbs but I can’t get a smooth surface.
So what does you mesh topology look like?
will be related to the surfaces of the boat
