please help me understand why this component is failing with this particular mesh. I know it’s quite a dense mesh, probably way more than needed, but it is also a healthy well made mesh. the bizarre thing is that by changing the light direction by a tiny fraction in the Z axis it works just as intended. at the end I think this component shouldn’t be failing.
Thanks for the file. I am not the developer of the Mesh Shadow component, so I cannot tell you exactly what is going wrong inside it. But the behavior you describe is worth logging, so I have.
