Mesh Pipe plug in?
I have been looking for hours for a plug in called mesh pipe but there is none, and this is what comes up when I open the definition.
I believe that’s the one from Mateusz here:
I tried that one but I get the same unrecognized Voxel object window when I open the script.
Did you installed the plugin correct? Unblocking files etc.
Yes I have installed it correctly but still it dosent work! I have rhino 6 could that be the problem?
Hi, the link @DanielPiker sent is actually the first version. The one you are looking for is here: https://www.grasshopper3d.com/forum/topics/mesh-pipe-and-sweep-mesh?groupUrl=milkbox&
You must join the milkbox group first.
Do you know how I can join the group?
@diana.daoud
You should be able to go here https://www.grasshopper3d.com/group/milkbox and join as long as you have a Grasshopper3d account.
You click Join :grinning: (upper right side)
Thank you so much!! :smiley: It all worked out. :star_struck:
Can anyone confirm if this is still working? I joined milkbox and downloaded from the latest link, and it’s still not showing up as a component.
It works, i use it often.
I can’t get this to install, either. I downloaded the latest link, but it didn’t work :confused:
Could you please share your gha. file with us? Maybe it works :thinking:
if you are on rhino 6, you could make your own mesh pipe component.
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Mesh_CreateFromCurvePipe.htm
a rough example here: (as mentioned in the post, the intervals are optional).
What version of Rhino are you using?
So what you’re saying is that it 100% will not work for Rhino 6? If it’s possible, does someone have a version they can upload?
This particular plugin is a dependency for another script I’m trying to use, and I’m attempting to get that specific look, so I would rather be able to use this version. Thanks.
I’m not saying it 100% won’t work. I’m just saying that, as an alternative…if you can’t get your current mesh pipe component to work…it’s only a couple lines of code to make your own, that will do pretty much the same thing?
You can also try to use ngon plugin.
I have both Rhino 5 and 6. It works fine in both. I have the same gha from milkbox group. The mesh tools components don’t have their own tab, they go into grasshoppers mesh tab.
