Mesh overlapping
Hi All,
I have this file which has zoning areas as meshes and colorised. I am using an api to get this information and rhino3dm to bake them into a rhino file. The problem is smaller meshes get hidden underneath bigger ones and this is problem because I need the smaller meshes to be visible on top. Is there a way to do this?
I’ll attach my ghx file which actually does the sorting and creation of the meshes.
zoning.ghx (85.2 KB)
Thanks
Your def contains things:
that I dont have.
PlanB: Since R Methods related with Mesh Bool ops (including Split) … well … work when they work, a rational solution (case: planar flat Meshes) is to extract the inner/outer Boundaries (as Curves) and then do something like this:
Then redo the Meshes out of the resulting BrepFaces.
This is kinda flying from DC to NY via LA … but it works always.
Nothing in your GHX
@PeterFotiadis @Quan_Li
Attached here is the gh definition without any plugin components, also 3dm example of some zoning curves I want to mesh.
zoning.gh (7.3 KB)
output.3dm (324.7 KB)
Thanks
Where are the meshes? Internalize the mesh data and upload gh file only.
Sample ANY collection (overlapping or not - makes no difference at all) of valid closed curves/polylines/cats/dogs/whatever into a GH Crv Param component, internalize data and post a gh def containing ONLY that Param (or your Crvs or your Meshes in a R5 format file).
Forget all the rest (for instance how to re-assosiate the results with any kind of original meta data etc etc).
zoning.gh (2.6 KB)
Appears that today is Not your day (blame Karma).
zoning.gh (199.9 KB)
Try this
BTW: Curves are not checked: just a first pass on all Crvs VS all Crvs Ccx
BTW: Did a fast “entry level” Poly check. Some of your things have a lot of vertices (solution would be waaaaaaaaay faster if they were … a bit more rational).
mesh.gh (1.0 MB)
Here is the meshes for you @Quan_Li
Curve is ok.
Overlapping means they stay at same plane, so you just need to move them tiny bit upward.
zoning (1).gh (223.1 KB)
Unfortunately, I cant control it because the vertices come straight from the API.
5 minutes spend on that matter (but the real thing MAY require a day [min]) : meaning that hope dies last (but it does)
UPDATE: your things are like these: meaning a LOT of colinear vertices. Meaning that an other far more suitable C# is the thing to use first: I’ll test one (out of many available related with Polylines etc etc) soon.
For instance. From here:
to there:
