Hi all,
I have a polysurface which I turn into a mesh, and I do it by accessing the command line either form Rhinoscript or C#. If I suppress the dialog box popping up for mesh options, no matter what values I insert to the options, the resulting mesh is open, while if for the same polysurface I do not suppress the dialog box and simply press OK, the mesh is closed.
Any ideas?
What I actually want to do is to create a mesh with the higher possible amount of polygons.
Thanks
