Not sure if this is a bug, but the mesh.NormalAt method sometimes doesn’t return unit vectors. Is this on purpose and should I trust the non unit vector directions as correct normals? This issue is easy to reproduce.
For example:
All inputs with default values. Code in the C# component is:
private void RunScript(Mesh M, Point3d P, ref object A)
var mp = M.ClosestMeshPoint(P, double.MaxValue);
A = M.NormalAt(mp);
Yes I can see that. I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-48292
In the mean time, you can just unitize the vector yourself.
var dir = M.NormalAt(mp);
dir.Unitize();
A = dir;
– Dale
Thanks, mesh.PointAt() seems to also return wrong values. I guess its an issue with ClosestMeshPoint().
Using mesh.ClosestPoint(point, out closestPoint, out normal, distance) returns the correct closest point and unit normal.
This has been logged as a Rhinocommon issue, but it might not be. Both NormalAt and ClosestMeshPoint methods just wrap native methods.
Mmmmmmkaaaay, that explains a lot.
Now I can let my bald spots grow out again…
// Rolf
