hello,
does coverting my model into mesh will make it lighter in size and easier to navigate ??
… and if so does my material stays embeded in it ?
Hi -
In large scenes with lots of objects, using meshes can speed up the display, yes.
When you use ExtractRenderMesh
, the material of the NURBS object will also apply to the mesh object.
When you have several objects that share the same material, you can join the meshes into a single mesh to further speed up the display.
