I’ve a strange problem with mesh load. I’ve created several quad mesh from point and applied mesh loads to simulate loads transfer of unidirectional plates. If i use “line loads” option some of line loads are correct and some are not (meaning that the sum of line loads doesn’t match the mesh resultant); if I use “point loads” only, the sum of point loads is always correct…
[See the images below > The meshes have approx the same areas and same loads]
IMG_01 - Resultant line loads
IMG_02 - Resultant point loads
IMG_03 - Setting of the right mesh in the images
IMG_03 - Setting of the lesf mesh in the images
I really can’t understand the trick…
