Mesh issue
So I was given a mesh of building and I need to cut out the columns in the front. I can make the boolean cuts to cut out the columns however everything is still all connected together. In other words it is as if everything is joined together. Any advice? thanks!
Hi @intuitionusa, try _SplitDisjointMesh or if this does not seperate the columns, explode the mesh and join what belongs together. _Explode will put things apart along unwelded edges. If you want to extract from the mesh without exploding, you can use one of these commands too:
ExtractMeshPart
ExtractMeshFaces
ExtractConnectedMeshFaces
_
c.
Wow, that got it. Thanks!
