Mesh going weird!
Hello can someone look into my script what is going wrong! The last output is too messy! There is a mesh that start from top to bottom outside the column , I want to omit it!
unnamed backup.gh (20.2 KB)
I’m not using mesh explode and nudibranch therfore had to replace two components. Not exactly sure what was wrong with your definition unfortunately. However instead of the mesh surface components you could use the Simple Mesh (selected / green) component since all you really need at this point is a mesh and no division.
Two components downstream I added an Align Vertices component. Don’t ask me why but it helps join or weld the vertices of the mesh.
named_mrtn.gh (31.0 KB)
Thank You So Much!!! :blush:
