Mesh GetNakedEdges Fails
I’ve run into a mesh geometry that is causing the call to Mesh.GetNakedEdges to fail to return, causing Rhino to become non-responsive. Although I would say the mesh not of an especially good quality, having many degenerate faces, Mesh.IsValid still returns true. Below is a sample command that demonstrates the issue, along with the problem geometry I am attaching. It would be ideal of course if GetNakeEdges could return the desired edges or at least null, but failing that is there was a way to tell apriori that this mesh will pose a problem for GetNakedEdges?
Thanks, Larry
public class RhinoMeshNakedEdgeTest : Command
	public override string EnglishName => "GetMeshNakedEdges";
		if (RhinoGet.GetOneObject("Select mesh to get naked edges", false, ObjectType.Mesh, out ObjRef objRef) == Result.Success)
			var nakedEdges = objRef.Mesh()?.GetNakedEdges();
			return nakedEdges != null ? Result.Success : Result.Failure; ;
		return Result.Failure;
MeshCantGetNakedEdges.3dm (7.6 MB)
Model Attached
Hi @LarryL,
Mesh.GetNakedEdges goes out to lunch because the method tries to join all the edges (e.g. line segments) into polylines. In the case of this mesh, there are a lot of naked edges - 472978 - so joining take a long time.
If you are just looking to find the topological edges that are naked, you can do this:
  var rc = RhinoGet.GetOneObject("Select mesh to get naked edges", false, ObjectType.Mesh, out var objRef);
  if (rc != Result.Success)
    return rc;
  var mesh = objRef.Mesh();
  if (null == mesh)
  if (mesh.IsClosed)
    return Result.Nothing;
  var naked_count = 0;
  for (var ei = 0; ei < mesh.TopologyEdges.Count; ei++)
    var faces = mesh.TopologyEdges.GetConnectedFaces(ei);
    if (null != faces && 1 == faces.Length)
      naked_count++;
  RhinoApp.WriteLine("Total number of mesh edges = {0}", mesh.TopologyEdges.Count);
  RhinoApp.WriteLine("Number of naked mesh edges = {0}", naked_count);
  return Result.Success;
– Dale
Thanks Dale!
I think that’s all I really need. I need to draw the edges in a display conduit (but only need to calculate them once). I’ll give it a go a see what the performance looks like.
Larry
