Mesh geometry is not solid!
How to delete these polyline from a set of mesh? When i calculate the volume of mesh,a warning shows “Mesh geometry is not solid!”
捕获
The message indicates that you have holes in the mesh.
You can either apply the command Mes > Repair Tools > “Fill All Holes”, or post the gh-file so we can inspect the mesh and give better advice.
//Rolf
Voronoi-base-1.gh (20.8 KB)
I try to use Voronoi tool to make a porous geometry,but sometimes it doesn`t work and export an warning.It may take several minutes to open this gh file.
