Hi all,
Any idea how to make mesh from a list of Line segments?
I have a curve frame/ divide those curves by 0.25 and convert them into 0.25 Line segments/
Then I want to generate a mesh from those segments.
Any help would be appreciate!
(Min/ Max of mesh should be equal to segments length)
Thank you Kim, is there any way to fix error “1. Solution exception:Index was outside the bounds of the array.” If I want to use Simpleremesh your first solution?
